No Spark F22 Round 2
    Ok so last night I again put in a new igniter(ignition control module) a new coil, new wires, new plugs, new relay, new ignition fuse and still no spark. Anybody have any ideas what the hell else it could be? I'm about done with this car.
    1992 Accord EX Sedan F22 Auto
    2007 Chevy Cobalt LS 2.2 Auto
    nobody anybody have any idea... I want this CB back on the road.
      check all your grounds
        You said ignition fuse, but did you check the main fuse? It's a 80A or 100A fuse.
        Other than that, grounds, and check your plugs going into the dizzy.
        1992 Prelude S w/swapped H22A
          well we found the problem last night. The pin that holds the cam and cam gear sheared so the gear was spinning but the cam and the distributor were not. Put a new pin in and she fired right up. Its amazing how a 13 cent piece can do so much.
            I'm having a similar problem, but my issue is that the main coil is not puting out any spark. I tried cranking it over with the main coil wire near the head so it would arc outward to show me spark, nothing... I checked the IG Fuse and main fuse and still nothing. ecu fuses are fine to. I'm about to pick up a u pull it coil pack to try out... after that I'm going to throw another ecu in.
            BTW the big gauge wire that goes into the coil pack has 12v when ignition is turned on. The other two wires dont put out any power... if they are supposed to, I don't know.
            HELP!
              Ok, it was the same damn problem you had! Pin sheered right off, where did you get it, where can I get it? 13c?
