i have a quick engine
    sorry dude i post before i read. only because its 1:10 in the morning were im at and im tired
      its cool, just make sure u read before u post next time.
      www.hmotorsonline.com has the best reputation i have seen.
        ok so what would be the difference in power with the f22 tranny compared to the h22 tranny
          it wont stay in VTEC from gear to gear.
          its not the right gearing for the H22.
          H22 + H22 tranny is what you want.
            1:20 here as I'm reading this Been up since 7am.
            Anyway, yeah... do some research. It's YOUR car, YOUR money, and YOUR needs and desires that this swap has to fulfill. We can help, but "what should I do" is a lousy question. What would I do? I have an H22. I paid a shitload for it 5 years ago. That was my choice. The F20B was around then as well... but I went for the easier swap, the more common engine, and the more supported engine within the aftermarket. At the time, having an H22 in a CB7 WAS an uncommon thing. People drooled over it. Now, it's only slightly uncommon... and often sneered at as the "easy" way out.
            Do what you want. If you can't afford to do something right, don't do it... save until you can. I can see you buying a $500 engine from some shady shop, getting the engine 6 months later with a broken camshaft and a hole in the block. That, or you'll get the motor in, run around with the long-geared F series transmission, say that it sucks, and sell the car to someone else... who won't appreciate it because they didn't do any of the work.
              There is no difference in power. The transmission only puts the power to the ground. The engine makes the power.
                do you kno any were that is selling those both together for a grand
                  no no im not tryin to half ass it
                  im going to bed i will check this in the morning
                    See my post above
                    Save for a good setup. You CAN find it all for a grand if you look, but probably from a private seller. NO reputable engine importer will sell that cheap. Any that would will be likely to sell you garbage.
                    If you can't afford to do it right, you shouldn't do it at all.
                    And yes... looking for something that sells for $2000 after shipping from most places for half that price... is half-assing. I'm as cheap as the next guy (believe me... I have NEVER paid full price for anything since I overpaid for my swap!) Still, there are some things you should NEVER go cheap on. Motor swaps, internal parts, turbo, electronics, brakes, suspension, and tires are some of the major ones.
                    Put $2000 into your swap. Put $800 into your suspension. Put $500 into your tires, and $200 into your brakes. That's just $3500... Sure, probably twice what you paid for your car, and only part of what probably needs to be done (I'm SURE you have rust holes in your rear quarter panels... at least one...) but it's a good start. Do it right, and you'll actually like your car. Do it wrong, and you'll be PMing me for the password to the Classifieds section so you can sell your car (and no, I won't give you that password...)
                      very well put. I am one of many who can tell you that hmotorsonline will not let you down. Im in the process of the h22 swap and think it is fairly strait forward. I regret not doing as much research as i should of before i dug in.
                      My advice is to spend some time looking at all of the swap threads to get your head on strait about what is necessary to complete both the F20b and H22 swaps and then decide for yourself. G/L with the reading
                        if u've ever heard of jhot they are one of the largest jdm importers in the business....u can get a full h22 swap with longblock, tranny, ecu, harness, and axles for $1500 + tax but even goin this way u still have to to change the distrubitor depending on whether or not its internal or external and u have to run 3 wires for vtec. Its just something that happens when u put a motor in a car that it wasnt made for.
                          whats the the hp on the h23 i have been looking and i think im missing something
                            http://www.cb7tuner.com/vbb/showthread.php?t=39834
                            anything u need to know about any motor that will fit in an accord
                              would it be bad if i put the h23 engine on with my tranny? or would it be okay?
                                whatever engine your decide to get the fact is that the h22 trans will own the f22 trans so if you want to do it right then get a transmission with your engine and do not cheap out or dont do it at all
