what would be a better engine for my 92 accord. a f20b or an h22a both standard
i have a quick engine
Originally posted by BootlegCB7but remember, upgrade your suspension before your engine....
Next project car, will have sus work done 1st!**Blk Housed Slut Crew Member #1**
Your car is OBD1. Unless you want to change all your wiring to make it OBD2, you'll want to change the engine (OBD1 distributor, OBD1 ECU... meaning you can't use the F20B ECU)
Also, the stock F22A trans won't really be great with the high-revving F20B. You'll have to rev to the moon to make power with that engine, and with those long gears, it'll take forever. The H22 will be faster with that transmission than the F20B would be. The H22 transmission, or H23 transmission, would be more fun. You CAN do it, but it will detract from the enjoyment.
My advice, learn a good deal more before you drop money on it. Learn more about the transmissions, the powerband of both engines, ECU options (and custom tuning), etc. And by learn, I don't mean regurgitate everything people say with a question mark at the end. Feel free to ask questions, but your questions will get MUCH better replies if you show some initiative and learn a bit on your own. Nobody wants to repeat something that they've said a million times... when it's very easily found and referenced here on the site.
wow please read what deev wrote.
the h22 would be your best bet as it seems you dont want any hassle in this process. just like he said, u can keep your tranny but the F tranny and H motor dont mate all the well. fitting wise it is perfect, gear wise it is not. the best way to go is H motor/H tranny.
if it would be better staying with the h22 i would rather have he h22 but if its critical that i need a better tranny such as the car barely works than i would really like it if you guys could point me in the right direction so i can find a cheap engine and tranny. also just to let you kno im only 17 and i will be doing this engine swap myself so any tips let me kno
