Ok so my timing belt went about 3-4 months ago and I'm finally getting around to work on my honda. I got the timing cover off(nobody told me what a pain) and got the valve cover off and etc.
The timing belt is shredded into pieces and i went to pull it out and it kinda just ripped in half from where i guess it must still be in place on the bottom.
anyways out of all 16 valves, 8 sets, 1 set is down. I've always wanted to know by bent valves, is that what you guys mean? Anyways yea so all the rest are back and 2 are compressed.
The head is full of oil and i got a full pan of oil. That means that my block probably survived, correct?
Anyways so what should I do with those 2 valves. I was told to take the rocker arm off and see if they spring back but I don't see how to do that.
In other words, from what it seems is that on the camshaft, the parts on the camshaft that hit the rocker arms only 2 of them got misplaced or w.e it is?
You know how theres number listed 2,3,4,5.
It's the one corresponding with 3. the one closest to you as if you were looking at the engine from the front.
What should I do?
What should I do?
