I bought my cb7 with a f22b2 bottom end in it, i want to buy headers, do i have to order it for the 97 that it came out of, or can i just buy as if it was the stock engine, basicaly is there any difference in the headers from 91 to 97?.
headers
Originally posted by deevergoteNot sure. The F22A1 was 4-1, so that may be as well. I really don't know, nor do I care!
NINJA EDIT!
If its the same header as this one, there would be no point of upgrading to a stainless steel one. If you have the header with one pipe going into the flange going to the downpipe, then at that point its a beneficial upgrade.Last edited by js593; 02-18-2008, 02:09 PM.90 Accord EX F22a1 Auto R.I.P.
2011 Mazda 3 Hatch 2.5L GS sport HELLO!
I wasn't being harsh... just that I don't really care for these motors.
Do you understand how a header works? 4-1 is actually what race headers use. 4-2-1 is better suited for street cars, and provides more low and mid range power in exchange for top end. The type of header has nothing to do with the size of the primary runners. Most stock headers/manifolds have smaller diameter piping to provide low-end power. Grandma doesn't drive around at 6500rpm!
The H22's primaries are not 2.5". 2.5" is a good size for the collector that merges all 4 pipes, and for the exhaust piping that carries the gas from all 4 pipes. I do not know the stock diameter of the H22's primaries, or the diameter of the commonly used piping, but it's smaller than 2.5" for sure!
Also, the F22B header in the picture (quite unrelated to the F22B1/2 in question) has a cast iron manifold, which has very thick walls. The inner diameter of those runners is probably the same, or even less, than "smaller" headers.
Originally posted by deevergoteWon't fit properly. Why would you want to do that anyway?Freedom Is Not Free
U.S Army 02/08 Medically Discharged
