could it be the AC??? or the water pump???
Screeching noise!!!
Originally posted by c-los0529So today i took the alt. off took it to auto zone and got it tested. It is good so i took the front cover off the engine the one behind the crank. The belt look a little scratched so i cut off a few peices off, i put the alt. back and it still made the same anoying noise. The belt is new so please i need some help what can i do???
Originally posted by c-los0529Yea i thought that the noise might be coming from the plastic rubbing the belt cause someone had metioned it so i cut a few peices of but it didnt fix nothing.
A simple way to figure out which belt is causing the problem is to take the PS belt off, start the car, and see if it squeals. If it still squeals, then your Alternator belt is the trouble maker. If it doesn't squeal, it's the PS belt. Either you need to tighten it up or loosen it. You should be able to flex it between 1/2-1/4 inch either direction when you have it right.1992 Prelude S w/swapped H22A
I also have the same problem, really hate that sounds. Its an (ACURA CL "98) I replaced a Acura CL Steering rack (don't know if its gonna work on you)power steering belt is the main cause, check to see if its too tight. there should be no more than 90 degrees of deflection (twist) in the belt at its furthest point, check between the A/C compressor and the crank pulley for it. replace it and drive on. Hope it works...
All right it is the alt. belt but this may seem wierd or not i dont know much about cars or whatever. But i rememberd that when i got the car i put a big battery in it and it squeeled like it does now. I had it running with a 98' sentra battery until my head gasket blew. Different story but right now I disconnected the battery and it stoped squeeling so maybe its my battery? I dont know what kind goes into it but right now its got a battery from a 93' legacy.
Originally posted by c-los0529All right it is the alt. belt but this may seem wierd or not i dont know much about cars or whatever. But i rememberd that when i got the car i put a big battery in it and it squeeled like it does now. I had it running with a 98' sentra battery until my head gasket blew. Different story but right now I disconnected the battery and it stoped squeeling so maybe its my battery? I dont know what kind goes into it but right now its got a battery from a 93' legacy.90 Accord EX F22a1 Auto R.I.P.
2011 Mazda 3 Hatch 2.5L GS sport HELLO!
Originally posted by c-los0529Ughhhhh!! every time i start up my car the alt.belt screeches and i hate that. Rite now i went to go pump some gas and it would not spot making that noise, I HATE THAT NOISE! well anyway i changed my belt but it still makes the same noise please help me i dont know what to do anymore.
Originally posted by c-los0529Well i guess it is my bearings then, cause it does it when i start it and when its cold too. And thanks you did answer my question. So should i just get the bearings or the whole rebuild kit?
well i know this is going to sound silly, but have you tried shooting some belt dressing on it? that happened with me on my camaro even after i replaced the belt with a new one. a can should run you about 3 bux so you really have not much to lose. if that doesn't do the trick then move on to the more expensive alternatives
autozone has some belt dressing in those little packets, maybe try that? you apply it under the belt and its supposed to reduce the noise.1993 Honda Accord EX-R Coupe Granada Black Pearl
///Alpine CDA-9847 Head Unit
OBX Pedals, stock air box, Ebay headers, Stock dual tipped muffler. Emblems removed, grill chrome painted black.
1993 Kawasaki EX500 Flat Black. First Bike.
Hey I did the belt dressing stuff and strayed it on while the belts were moving and it splashed all over the damn place and there is this sticky residue.
I also sprayed a little on the mounts to see if that would do anything to them... hopefully good. and I dont think its done a damn thing but Ive noticed more squeal after wards and obviously a bigger mess.
it honestly doesnt bother me cause this car is rust bucket I just bought for getting around town. but if there is a simple fix like retorqing the bolts or pulley than i might have to try it.AD5OS
FOLDING@home
