Screeching noise!!!
    Screeching noise!!!
    Ughhhhh!! every time i start up my car the alt.belt screeches and i hate that. Rite now i went to go pump some gas and it would not spot making that noise, I HATE THAT NOISE! well anyway i changed my belt but it still makes the same noise please help me i dont know what to do anymore.
    Tighten it more
    1996 Honda Civic LX 2009-2012
    2012 Kia Optima LX 2012-2013
      Originally posted by DarkShadow707
      Tighten it more
      How tight? Can i over tighten it?
        I got the same problem..... I hate it
          To tighten it just crack all the bolts loose on you alternator, a 14mm up top and 12mm i believe on the bottom and two 10's on the front bottom but the right one you barely loosen and the other you tighten where the belt is where you want it. A half inch of play is about right. Then tight the other three back up.
          -1991 Honda Accord LX H22a-
            It will squeal if it's too tight as well... and do damage to the alternator.
            I believe you should have about an inch of play in the belt. Double check that with a manual.
              i had the same problem on my f22a1 an i changed both belts and about two days later the noise came back! so i looked closer at what it could be and in the end it turned out to be that the plastic cover to the timing belt was bent and it was scratching on one of the belts , so i cut a piece of it out and now it doesnt make a peep ... =)
              I sell slightly used tires for cheap, jus pm me what u need!
              Hp sells cars, Tq wins races ....
              - 95 Camaro (beast) TOTALED
              - 92 Camaro RS (fixer-upper) SOLD
              -92 Accord LX (slammed) SOLD
              - 95 Jetta (VR-SEX) CURRENT DD
                Does it only do it when it's cold? Tighten it making sure it has a little play, that should do it. Check the other belts too.
                Former: 90 LX, 91 EX. Current: 92 LX
                  sometimes, as a result of an overtightened belt over a long period of time, the bearings inside of the alternator wear out and create the same type of noise. it seems to me like you got so pissed at the noise, you just tightened and tightened. I would look into either a rebuild kit or a refurbished alternator my man.
                    along with an eventual failure of your alternator.
                    ^^click it or ticket^^
                      so did we answer ur question??? or solve ur problem ???
                        Well i guess it is my bearings then, cause it does it when i start it and when its cold too. And thanks you did answer my question. So should i just get the bearings or the whole rebuild kit?
                          Allright so i need some help please wich should i get the whole rebuild kit or just get some bearings? PLEASE HELP!!
                            So today i took the alt. off took it to auto zone and got it tested. It is good so i took the front cover off the engine the one behind the crank. The belt look a little scratched so i cut off a few peices off, i put the alt. back and it still made the same anoying noise. The belt is new so please i need some help what can i do???
                              Your sure its not the powersteering.
                              wat?
