Hole in Wiper Fluid tank ><
    How do i change the tank? I got like a hole from the car wash >< (They cracked my windshield and my wiper fluid tank)
    Thank
    How did they cracj your windshield???
    I dont know what kind of liabilities there are, but id look into that first. And they tank is behind the bumper...unless its cracked from underneath...
    Im not 100% certain, but im pretty sure you have to remove the bumper to remove the tank. I think its just a bolt or two up top, in the engine bay and a few underneath, once you get the bumper off.
    Originally posted by Jarrett
      Yeah, defiantly look into liabilities issues from that car wash. If all else fails, protest. :P
        this happen long time ago. I replaced the windshield already. is that i keep driving with hole in my reservoirs and every time i fill the fluid some of it stay in the tank and some leak go onto the ground. I just want to replace it now.
        Thank! i'll take a look into that. when it warmer out
          Im pretty sure my tank is solid, but someway, somehow, it leaks when i fill it. I think where the neck meets the tank has a crack/leak, cuz i can put quite a bit of fluid in there, but it never gets completely full.
          Like i said, im not completely sure, but you may be able to remove/replace it without removing the bumper...
            i got to look on how to remove the bumper first ><
              I dont wanna freak ya out, but if my memory serves me correctly, itd be a good idea to disconnect the batery cables for like 30 mins then i think its just like a dozen bolts/screws/clips.
                Do you look in your driver fender? I am not sure because i have a custom bumper and i remove windsheild washer tank and black plastic fender . But i think if you raise your car and take off front left rim maybe you can have acces at your tank.
                  hmmmm time to get some tools ><
