166K miles on seafoam
    is it bad to seafoam my engine even if it has 166k miles?
    Through the throttle body and in the gas tank no issues
    *EDIT*
    their site says to add about 5-8oz (1/3 pint) to the oil...I'm not fan of their next recommendation (spirited driving and high revving)...but 2 to max 3k and you should be ok...have to change oil RIGHT after...if it were me I'd change it twice...cheapo filter and oil first...then good stuff second.
    Either way, I'm not fan of adding stuff to oil other than oil though.
    166k is YOUNG for accords though
    Clean that TB every 15k...it gets dirty quick...search for oil catch can on the forums and you can see one reason why.
    ____
      I seafoamed an older integra. It had no problems what so ever. Try it and see how good the stuff is.
        I read this some where
        The rule of seaform in Engine Oil is that you pour like 1/4 (i think) of the bottle, drive like you normally do and must Change the oil before 100 miles
        that what i did and nothing wrong with my car. The oil was BLACK BLACK
        it not going to damage the engine they even said that in the back or something. it an oil base product or something
          yeah that's the rule...I think that amounts to like 5-8 ounces 1/4-1/2 of the bottle that is.
          A lot of guys have done this and none have had issues.
          but 166k...seriously...YOUNG for a cb HA HA
          What people also say is be sure to do a full oil change afterwards, filter and all.
          ____
            I just did Seafoam on my CB. Oh, it drives so much better now. Smoother idle, accelerates better too. Its worth the investment.
              the dirtier the engine the more improvement it will make.
              the cleaner the engine the less improvement it will make.
              my engine is CLEAN...little improvement. (I do top engine cleans routinly)
              my tb gets dirty around every 15k at the least...usually more (until I install catch can) but again, I clean that all regularly.
              last t-belt I did i inspected everything...all clean...not polished aluminum clean but nothing major.
              Still...top engine cleaners and the such are great preventative maintenance items.
              ____
