pt3 in a f22a6?
    pt3 in a f22a6?
    I have a 92 EX and when I was jus lookin around the engine I noticed somethin in the back that said PT3, and wonderin if/why I have a pt3 in my car since I have the f22a6 motor it should have the pt6 right?
    The only thing that I believe is pt6 is the ecu I have an a6 intake manifold and it has pt9 on it. Everything else on the vehicle other than what is specific to the ex like abs is the same as the lx.
    I need a 14b or 16g turbo!
      PT3 is a common p/n reference for CB7s for alot of engine/electical related stuff. I wouldn't read too much into it. If it bugs you, what was it on? I can look it up and check the p/n against your model.
      1992 Accord EX 4dr 5spd - SOLD after just over a decade of ownership
      2000 Subaru Legacy GT wagon 5spd
      AHM Platinum Parts Counterperson
        yeah i dunno what it's on, but if you guys are pretty sure i'm good then i trust you hehe, thanks anyways!
          PT3 stamped on your engine doesn't mean you have a PT3 ECU. If it bothers you, pull the ECU out and look at the label. It will read PT6.
          Do your IABs open? You have a PT6.
