New gauges =D
    New gauges =D
    So i got some new gauges and a CF gauge bezel =D problem is how do i get the gauge cluster out? and is there anything to keep in mind when i take it apart to put these gauge faces in? it also comes with a dimmer knob to change the colors and/or brightness anyone got a set like that and how did u wire it? it came with directions but they are really vauge and i dont wanna mess this up so i figureded i see what u guys think?
    8 Accords so far:
    '81 SE Sedan(1st Gen), '83 SE Sedan(2nd Gen), '89 SE Sedan(3rd Gen)
    '89 DX Sedan(3rd Gen), '92 LX Coupe(4th Gen), '92 EX Wagon(4th Gen)
    (3rd gen parts car) I'm currently Driving a '14 Accord Sport 9th Gen
    cliffs notes: (if you want more detailed info, search in the DIY section)
    to get the cluster out, you need to take the entire black trim out of the car. That is the black piece from your leftmost vent all the way to the cig. lighter. Remove all the vents, buttons, and screws (about ten of them, mostly all are hidden).
    Once you get that off, there will be 4 screws holding the cluster, and 3 harness plugs behind it.
    take off the plastic clear cover of the cluster
    remove bezel. install new gauges OVER the stock ones. Slide them over the needles, do not try and remove the needles.
    If you want, you can add some tape or glue to hold the new gauges down so the needles dont hit them and stick during acceleration, etc.
    install your cf bezel
    run your wires behind and tap into a 12v source (i used the dimmer switch near the cluster)
    reassemble
    Formerly 91AccordExR33
    11.68 @ 127mph
    417whp/375wtq
    Sold: 8/2016
      aight thx alot man so i just glue these new ones to the old gauges?? they dont stick out to far for the needles to move when u do that??
      8 Accords so far:
        mine didnt. i used a tiny bit of super glue and the needles still cleared easily
        and make sure you dont move the gas gauge needle until you REMEMBER WHERE THE NEEDLE WAS WHEN YOU STARTED
        11.68 @ 127mph
        417whp/375wtq
        Sold: 8/2016
          heh k thx bro so what nedles actuallyhave to be removed? just gas and temp? ima head down to the shop and give this a try after i finsh breakfast/shitshowershave haha u kno how it is.. well wish me luck
          8 Accords so far:
            DO NOT REMOVE THE NEEDLES!!!! YOU WILL FU*K IT UP!!!!!
            YOU SLIDE THEM IN ON TOP OF THE OLD ONE'S!!!
            YOU WILL HAVE TO REMOVE ALL THE SCREWS FROM THE DASH.
            ITS ABOUT 13 SCREWS
            4 FOR THE DASH
            IF YOU HAVE A 92 -93 MAKE SURE YOU TAKE OUT THE STEERING WHEEL TOP COVER SO YOU DON'T SCRATCH IT UP!!!
            AFTER DOING ALL OF THAT MAKE YOU YOU TAKE OUT ALL 3 CLIPS TO THE CLUSTER, THE TOP ONE IS KINDA A BITCH!!
            Links to my rides :
            1992 Accord EX*
            1990 Accord EX
            1991 Accord SE (4th)
            1991 Accord SE (3rd)
            1991 Accord SE (2ND)
            1991 Accord SE
