I noticed today when I started my car this morning to let it warm up and after it was started it was running at about 1700 RPM's and after about 1min. I hit the gas pedal when I was getting in the car and the Rpm's started jumping from 1500 to 1000 back and forth so I held the gas pedal down for a little bit to bring the RPM' up to 2000 and when I let off it idle down to about 800 RPM's .My question is what would cause it to fluctuate
RPM Jumping at warm up
Originally posted by starchlandis it just the tach jumping or is the engine and the tach doing the same thing?
i just look at sticky to see what FITV IAVC stand for ><
and i got this http://www.cb7tuner.com/vbb/showthread.php?t=65668
i guess that the solution to your and mine problem
got to love cb7tuner.com
oh what does FITV and IAVC stand for?
Yeah do those tests before you replace anything because I assumed it was my fast idle valve. After I found out that it sucked in air when the engine was cold and stopped suction after operating temp was up I didn't have to replace it. I believe my problem is a mechanical failure in the IACV..
throttle position sensor. if you plan on replacing the iacv then try cleaning it first with throttle body cleaner. sometimes it gets gunky. good luck!
no
Accord turbo kit under $2k here
$30 HID kits here Thread
"What a selfish bitch. She looks like one too. A smart-mouthed, facebook-ing, "i dont know if im straight, bi or *** yet" little brat." -greencb7inkc
"No Herra Frush, Slammed, tucked or frame dragging here. I'll leave that to the mini trucks...." -fishdonotbounce
It's already been said...
but its def the FITV
My car is an automatic, I started it, it idled fine, then as soon as I put it into drive and hit my brakes at the first stoplight, it started surging from 1500rpms to 800rpms. Car never died, nor did it act like it would but after I cleaned the FITV problem was SOLVED.90 accord EX automatic F22A4 232,500
DIY ram intake
0gauge/4gauge BIG 3
stock alt rewound to 120amps
optima orange top 830cca 1030ca
fully synthetic valvoline "Max Life" 5w30
Other rides:
2004 Jeep Liberty v6
2001 Honda civic ex coupe 1.7 vtec
