Note that this doesn't mean that more or less total weight transfer is occuring because of a roll stiffness increase / decrease at either end of the chassis (though the totality of lateral weight transfer will change if the 'G' force increases or decreases, which is likely), just that the front / rear distribution of weight transfer has changed.
This means that since less lateral weight transfer is occuring at the front end, the inside front contact patch is more heavily loaded than it would be with a softer rear ARB (or stiffer front ARB, or stiffer rear springs , rear dampers etc, though dampers affect transient weight transfer and not 'steady state' weight transfer), and the IF will be more resistant to wheelspin as a result. This results in more front traction whether or not you have an open diff or a LSD, but the affect is stronger with an open differential since a LSD 'artifically' decreases IF wheelspin (with less front weight transfer a LSD would allow even more traction than it could otherwise provide if more front weight transfer occured).
This is more or less the same dyanmic (front / rear weight transfer distribution) that causes a stiffer rear ARB (etc) to decrease understeer. Note that body roll is not a cause of weight transfer, but rather is a symptom of it.
The less body roll you have the faster weight transfer will occur (and the chassis will tend to be more responsive, and the less undersirable roll generated camber changes you'll get), but assuming the lateral acceleration remains a constant roll has no affect on how much weight ultimately does transfer (other than from a tiny change in CG location, the reality of which is merely academic due the CG location change being minute).
When you have more roll stiffness at one end of the chassis than another (by any means, i.e. stiffer ARB, stiffer springs, stiffer damper rates, localised chassis stiffening members such as tower braces etc) then weight transfer at the stiffer end will occur more rapidly than at the softer end, but higher roll stiffness at one end of the chassis will limit body roll in total, not just at the stiffer end of the chassis.
