Body roll
    Body roll
    hey what shuld i put on my cb to help men a minamise body roll i put a stut bar in the front. but it stell rollesrelly bad
    The Race Car
    stiffer springs and match it with good set of struts
      strut bars front an rear, lowering springs/coilovers, sway bars, good tires just to name a few things
      UNDERGROUND SOCIETY
      NEW COUPE MEMBERS RIDE THREAD COMMING SOON
        lowering options
        you can cut you're springs, in which i dont recommend it, it'll screw ure camber up real bad and your tires will wear uneven, get full coilovers, or just lowering springs is the cheaper option.
          yea i got lowering sping just not on there yet and i got a front stut bar.
          The Race Car
            Struts play the biggest roll in body roll, springs too.
            wat?
              once you cover everything i stated ou should be ok, i have almost no body roll
              UNDERGROUND SOCIETY
                i got a set of tires that are on there now there better then the stock but i stell am sping the front in side tire coming out of the turns
                The Race Car
                  ok were can i get a bigger sway bar i cant find one on the internet do u no were can
                  The Race Car
                    quality parts come into play here...
                      You can get the suspension techniques front and rear sway bars or you can get the progress sway bar for the rear only as I have seen done on other members cars. By the way our cars stock sway bars are 14mm thick.
                      1992 Honda Accord Coupe LX
                        Not to be an ass, but if you typed in a somewhat coherent sentence with some sort of punctuation I would be more inclined to tell you that a company called Progress makes a good rear sway bar for the CB7 that pretty much eliminates all body roll.
                        Gary A.K.A. Carter
                        [sig killed by photobucket]
                          You spin the inside tire because you have an open differential. Nothing to do with body roll.
                          Quality struts are very important. Good adjustable ones, like Koni Yellows (Sports) are well worth the price.
                          Also, please try typing with your fingers instead of your forehead. It'll make it much easier for the people that are taking the time to help you!
                            hey her is an option SEARCH it will tell u everything eveyone told you on this thread
                            member ride thread >>> http://www.cb7tuner.com/vbb/showthre...73#post3257973
                              And telling people to search in the beginner forums will get you banned
                              Answer the damn question, or don't post. This is not the place to say "Search, noob!"... we're not Honda-Tech.
