will an h22 head fit on my f22a block
h22 top end
The F22 bottom end will provide a significantly lower compression ratio, and isn't designed to rev as high as the H22 head requires to make power. It can be done, but most F22A bottom ends have many miles on them...
If you want an H22, get an H22. If you can get a good deal on that head, then find an h22 block to go with it.
A full motor from a quality importer like hmotorsonline.com is expensive. Worth it, because you can be fairly confident that it'll be in good condition. However, you can find cheaper ones. There are JDM resellers that have significantly lower prices. Ebay has lower prices. US junkyards (hard to find one there) have lower prices. Or you could just piece one together. It'll take time, and it won't be extremely cheap... but you'll have a new motor if you do it right.
You either have to pay for it, work for it, or get lucky.
Doing the headswap won't get any significant gains. Doing that is like slapping on a tiny turbo because it's cheaper. You won't make the power you want, and you'll just be ruining a perfectly good engine.
I admit, I'm biased against headswaps... I think they're an awful idea... But, I have my reasons.
Seems like there are a lot of people lately looking to swap an H22 head onto their F22A bottom end. The H22A head isn't a magic silver bullet. Two of the main reasons the H22A makes such great power are high compression and high RPM, both of which are pretty much negated by swapping it onto an F22A bottom end. Stick with the F22A. For the same money that it would cost you to swap that H22A head onto it, you can mod it to make about the same amount of power with stock reliability and run it on 87 octane regular fuel, and it's a much better package for around town driving.~If everybody you knew jumped off a bridge...the bodies would pile high enough to break your fall if you jumped after them.~
Project Deerslayer
UPDATE: DEER - 2, CB7 - 0
'93 EX 5-speed coupe
Short ram intake
Tenrai Himoto catback
Smashed front end
Originally posted by deevergoteStill, you got a newer USDM motor... no emissions issues, not as old as an OBD1 motor, and I assume you can trust the mileage... there are benefits. Still 1800 will get you the motor, trans, and ecu from hmotors... and they're one of the pricier places.
Exactly. I was just referencing that to people that said h-motors was expensive. There are cheaper alternatives. But do you really want to have issues with your swap and spend mad loot trying to fix shit that you shouldn't have to deal with in the first place.Finally Up and Running. Numbers to Follow. Check my MR
Exactly. Buying a cheap motor, or piecing together a cheap motor, is like buying a cheap car in questionable condition. The initial investment may be small, but over time, it'll cost you more... and be less satisfying.
I spent nearly $5000 total for my H22 swap back in 2003, after all parts and labor (I paid to have it done... I really regret that now!). The shop I went to did a bit of a hack job, but it's been working well enough. The motor came from hmotorsonline, and it's still in very good condition. The only issues with it at the moment are due to my own stupidity... and it's holding up to that quite well also! I've known people to get cheaper motors elsewhere and have them fail due to no apparent fault of their own.
As for headswaps... even the guys that really know what they're doing have had one or two fail on them. If you're doing it for the sake of doing it... and doing it to a project car... then by all means, knock yourself out. If you're doing it to your only car, in an attempt to get some cheap, easy power... you are sorely mistaken.
