Transmission help:
    Transmission help:
    I need to know what I need to swap out if I wanna do an LX 5 speed trans to an EX 5 speed trans?
    why are you swapping? Something wrong?
    Pretty sure they're the same. So just the trans, i guess......
      does the EX tranny have less miles on it?
        They are the same. Gearing and all for the most part.
          those trany are exactly the same so what is it u need help with
            Nothing.
            You might have to tap some holes in the tranny for the mount at most, but i doubt that
            ----------------My 92 Honda Accord LX---------------------- My 97 Nissan 240sx LE----
            NE GUYS, Buy the last of my accord parts
              swap motors not trannies lol, the LX and EX 5spds are the same i think. only the engines differ F22A1 vs F22A6.
                Depending on the year, you might get the F22A6.
                As has been stated, they are the same tranny, but if you are going to do it...
                Definitely look at doing your clutch, pressure plate (if it is in bad shape) throwout bearing, Rear main seal, and axel seals while you are there. It's good preventative maintenance.
                If you are planning on really souping up your car, you might look at upgrading to aftermarket parts so you aren't covering the same ground twice.
                1992 Prelude S w/swapped H22A
                  Hes probably just changing it because his old trans is busted. Thats the only reason why I would think he wants the same trans. And do what benji said change the clutch, pres plate, and get a new flywheel if you can afford it. rear main seal is always wise to change when the trans is off.
