ga emmissions
    ga emmissions
    what do you guys suggest i do if i have too high off a CO% to pass.
    Prolly a new cat.
    1996 Honda Civic LX 2009-2012
    2012 Kia Optima LX 2012-2013
      i did that, a new cat, spark plugs and wires, changed the oil, and put a gas treatment, and if failed even worst than last time.
        Your EGR might be clogged.
        Fuel filter clogged.
          o2 sensor
            im gonna check the o2 sensor and fuel filter, but i also took out the egr and cleaned it, what about the fact that it is a f22b1 swap in there, should i tell them that, will it make a difference???-
              EGR is usually a NoX emission issue but not a bad idea to clean it. Make sure PCV is functioning right. Another thing that people dont know drive your car hard before you go to emissions. The cat needs to be hot to operate to its full potential. You go in with a cold cat or one thats not fully warmed your gonna get abnormally high numbers.
                someone told me to change the ecu to that of an f22b2, my question is does it make that big of a difference to where it would fail emissions that bad.
                click this link to see my results:
                https://asportal.vansis.wcom.com/asr...rptsrvr%3a8001
