How many degrees? H22a
    I want to know how many degrees of timing does an H22a take, i think its 18 but not sure, anyone know?
    what are you talking about? 18 degrees will kill a motor.
    miss my turbo cb7
      Actually a F22 Is 15º So...
      wat?
        what? u fo real?
        miss my turbo cb7
          what? u fo real?
          http://www.cb7tuner.com/vbb/showthread.php?t=55330
          wat?
            damm. now i would think the h22 is more
            miss my turbo cb7
              it depends what in the world your talking about, you have to be specific. Degrees of what? ignition or timing?
              ignition is 15 for h22 and f22.
                15 +/- 2 degrees btdc for your ignition timing. As for you mechanical timing, you just align the timing marks on the crank/cams, which will put you TDC for #1 cylinder.
                  haha yeah im sure the h is 15
                  smoke tires, not drugs.
                    Are you trying to set base timing or what. This question is so vague. As mentioned its 15 already.
                      For ignition timing, yes... 15 degrees +/- 2 (so 13 to 17 is safe). I've seen F22s with timing that was WAY off, and they lived. Still, I wouldn't push it. Especially with an expensive H22.
                      18 degrees probably wouldn't kill it, but it's certainly not correct. 18 degrees on crappy gas MIGHT do some damage...
