does anyone know if there is a way to adjust the shift cables to tighten them up?
shift cables
Yes their is a locknut you can loosen and then turn the cables connected to your shifter assembly, but usually that never needs adjustment and isn't the way to fix the looseness in your shifter, you could replace the cable bushings on the transmission with solid ones from corsport and replace the ones on your shifter with new bushings from a dealer.
Originally posted by 90goldcoupeYes their is a locknut you can loosen and then turn the cables connected to your shifter assembly, but usually that never needs adjustment and isn't the way to fix the looseness in your shifter,
Originally posted by 90goldcoupeyou could replace the cable bushings on the transmission with solid ones from corsport and replace the ones on your shifter with new bushings from a dealer.
Some slight degree of sloppiness in the shifter pivots is normal and there's not that much that can be done to improve matters (I'm not certain but I don't think the pivots are adjustable to account for wear). Fitting a short shifter will also reduce slop as felt at at the top of the gear lever.Regards from Oz,
John.
