Rear Strut removel
    Rear Strut removel
    What is the best way to get to the top bolts to remove the rear struts?
    fold the top half of the rear seating section down. remove the side panels in the trunk. you'll see the bolts to the strut there.
    miss my turbo cb7
      Thank's that sounds easy enough.
        Sounds doesn't mean is.
        They're not too hard, but make sure you do everything right the first time to save some hassle.
          its easy as crap, just dont strip anything
            Make sure the bolt at the bottom of the strut is not siezed before you bother doing anything else. It often siezes in the bushing and requires being cut off so a new bolt and bushing is required.
              with air tools lol
              My s13 Ride Thread>>><<<My Rx7 Ride Thread "What is power without control?"
              New people click here
                at work when they sieze I cut em off with a torch.
                Always use anti-sieze!!!
                  Get the bottom off first, I find that easier
                  wat?
