Junk Yard Find
    Junk Yard Find
    Just left my local Pull A Part and found a set of Tein S springs on a 91 Honda Accord. I also have a question when putting it together do you have to use the bump stop bushing and if so where can I get them?
    Not bad for $53.00
    try posting your QUESTION in the "Technical/Performance"...
      You can use your stock bumpstops but be sure to cut em in half.
      1996 Honda Civic LX 2009-2012
      2012 Kia Optima LX 2012-2013
        why is it important to cut them in half? is it to stop them from bottoming out? well i got coilovers and the fronts are fine perfect ride but the back is bouncing like crazy what can dat be? sorry for "stealing the thread" maybe da answer i get can help you also.
        clicky the siggy!!!
        ARCADIA GREEN MEMBER #20
        AIM=SleepygreenCB7
        Yahoo=annamaineeak@yahoo.com
          The shock body needs the extra room to travel.
            Thanks for the help. I will look at the stock ones off the rear tomorrow.
              WOW!!! why cant i ever get a find like that
                I took the front strut apart and cut the center out of the factory stop. The part I cut out is now about 1 1/2" is that enough to use for the rear? Also I did put the factory stops in the front that I took off at the yard should I take those back out and cut down?
                  nice come up...
                    Nice!
                      Yup, good find. Definitely cut the bump stop in half. I did not cut mine at first, so it was bottoming out when i go over bridges on the highway. Now good to go after cutting them.
                        Good find however, make sure they aren't knockoffs! Lots of them have been floating around e-bay as sellers were ripping people off. Check the tein website for more info.
                        "Thizz Bizz R' Uz"
                        Hear my pussy ROAR!
                        V-TAK
                        Variable Transistor Accumulator Kinetosizor
                          yeh no doubt awsome find, wish i had that kind of luck, o and if u have a bouncing problem, one of 2 things, cheap springs will bounce, or bad struts
                          Lost Motion Inc. Repair and Performance Automotive
                            Nice find sir.
                              Wow. When I went to the pull-a-part in Nashville I came up with nothing but a Honda emblem. The CB's out there were torn all to hell when I was up there.
                              Good Find!!
