h22a cams
    h22a cams
    what is the best cams to get without having to change anything???
    crower stage 1 cams, jdm type-s cams. Those are the ones that i know of which don't need upgraded valvetrain. Or no tuning required although it would be best to get them tuned to get the most out of them
      Any "stage 1" cam from most manufacturers will work. They usually give 12-15hp by the manufacturer's specs... about 5-7 short of the Stage 2 or 3 (depending on the manufacturer).
        x2 but if you gonna spend the money go for stage II unless you dont care to go fast?
        Freedom Is Not Free
        U.S Army 02/08 Medically Discharged
          x2 what? I didn't say get a stage 2. I said the difference is 5-7hp, and stage 2 requires a valvetrain upgrade. I was saying quite the opposite.
            then you'd might as well just pull the engine and do a straight up build.
            custom billet cams all the way!
            I <3 G60.
              Well, Stage 1 cams are a good way to bump a little more power out of the engine. If they aren't used for too long, they can be resold for around 2/3 the cost at least, I'm sure. That means a $500 set of cams can be sold for like $350. Not bad if a full build is in the future.
                if a full build is in the future, why even bother with stage 1. go stage 2 for a few extra pennies. the money that you would lose saling them can be spent on the rest of the valvetrain. so just do a lil more saving and do the whole valvetrain at once. especially if a shop does the install. pay them once, not twice.
                91 Ex CB9
                JDM h22 auto swap, now w/H23 5spd conversion, short ram intake w/K&N filter, DC ceramic header, 2.25" custom catback exhaust, AMR Engineering coilovers, 205/50/16's Enkei RS5's, front slotted rotors, Xenon body kit.
                W.I.P.
                p72 ecu on Hondata
                To Come
                Weight Reductions
                R33 or R34 front end
