Heeeellllllppppp
    Heeeellllllppppp
    No fuel or srark
    AUTO REOLUTION : A BAND OF BROTHERS FROM WEST TENNESSEE WE LIVE AND DIE BY THE NEED FOR SPEED
    see if you can pull any codes out of it,
      no check engine light. i changed main relay, changed ecu, changed dist, checked all the grounds and fuses dude im am lost
        did you check the battery?
          have you check your distributor
          it might be your coil. 75%
          borrow one from someone and try it
          -->751 whp @ 27psi <--...Midnight Tuning <----
            battery fuse?
            ignitor?
            gas in the car?
              ive done everything possible. fuses, ecu was changed, plugs, dist was changed, main relay was changed, grounds checked. what tha fuck,, im lost on this one
                do u get all the lights on the dash when u turn the key to II?
                  dose your fuel pump come on when you turn the key to on? do you have power when the switch is on?
                  Please, Leave me some feeedback on my ride ^CLICK ^CLICK ^CLICK
                  But Honda guys know EVERYTHING about EVERYTHING! If you don't believe that, then you're just wrong...
                    no fuel pressure at all, but i changed the relay and ckd the # 2 fuse
