When lowering?
    When lowering?
    when lowering a cb7 accord say 2" is the camber, alignment or toe gonna go all out of whack? my game plan now i got the progress sway bar on is to get H&R sport springs with tokico illumina shocks and maybe a energy suspension bushing kit. shoes will be 15x6 konig helium with fuzion Zri's.
    So will i have to spend more money on an alignment kit and whatever else so my tires don't wear in one season of driving?
    Thanks
    Lane
    1992 Accord EX-R 4 door Cobalt blue on blue 5 speed, friggin love this car.
    Performance mods: AEM short ram intake, Progress rear sway bar, and Apexi WSII cat back, skunk 2 wieghted knob, yeamans short throw. exedy oem style clutch pkg with a F1 racing 12lb flywheel, TASauto braided SS clutch line.
    Sound mods: Hertz space 6 1/2 speakers and tweets with a Audison Srx 2 amp, Focal 11" sub in a Focal ported box, Kenwood D-class amp, Audison cap and a Kenwood KDC891.
    You should always get an alignment anytime you change the suspension. As far as how out of wack it will be, get the alignment and then see.
      get camber correction blocks or a adj. balljoint camber kit. if you're 2" lowered, then yeah your camber is gonna be outta wack from normal specs and be prepared to spend $$$ for tires more than usual.
      member's ride thread
      91 Accord SE 176k
        I'm lowered 2 inches and I don't see any camber wear on my tires. They wear out like it's sitting on normal suspension. Equal and cute. The toe is what you need to be more concerened of , that's where my suspension is whack for now. But no biggie since I have the Firestone lifetime alignment.. I get it aligned every 3 months
        1996 Honda Civic LX 2009-2012
        2012 Kia Optima LX 2012-2013
          ok so i think the sports are like 1.75" front and 1.5" rear so i should be good?
            yeah you're alright. no need for camber kits.
              wtf. you have the firestone lifetime. i have that too and they won't touch my car. perhaps the wag us too long for their ramp or they just don't want to bother. anywho, check around town to see what shops are doing what. i had the hardest time the past 3 years finding shops that will touch my lowered ride, so she basic either sat or i drove it sparely since the tires are on their way out anyways. at the time it was only 2.25/2.0 now that i have coilovers its a drop of like 2.5 or 3 all around but now if found a ntb with a flush mount rack. so look around.
              91 Ex CB9
              JDM h22 auto swap, now w/H23 5spd conversion, short ram intake w/K&N filter, DC ceramic header, 2.25" custom catback exhaust, AMR Engineering coilovers, 205/50/16's Enkei RS5's, front slotted rotors, Xenon body kit.
              W.I.P.
              p72 ecu on Hondata
              To Come
              Weight Reductions
              R33 or R34 front end
                You alter any form of suspension work on your car there is going to be wear. Camber doesnt wear out too bad. If all else toe is what eats up tires quick.
                  I'd suggest getting an alignment right away but when lowering the car, just lowering, the only thing that will change will be the camber. If you correct the camber, then the toe will be out alot. But I suggest doing it right the first time, but w/ a minimal drop you should be pretty good w/ slight neg. camber which is good.
                    i lowered my car a little more than 3" and my tire wears very little unequal... not enough for me to mess the camber or toe ....
                    I sell slightly used tires for cheap, jus pm me what u need!
                    Hp sells cars, Tq wins races ....
                    - 95 Camaro (beast) TOTALED
                    - 92 Camaro RS (fixer-upper) SOLD
                    -92 Accord LX (slammed) SOLD
                    - 95 Jetta (VR-SEX) CURRENT DD
                      thats how it sits right now
                        ok
                        2013 Volvo XC90 Wife's
                        2002 Volvo XC AWD Ocean Race Edition 1 of 650 made Son's
                        1995 Volvo 850 Turbo (project)
                        1982 2WD K5 Blazer On Bags (well half is) Mine
                        1995 Jeep Wrangler Mine
                          Honestly, if the parts you're putting on are new, I'd wait 2-3 weeks to get it aligned and let the drop settle to where it's going to be, more or less.
                          As others have said, it's the toe you need to be concerned about more than camber. Too much camber is never good and you will have wear issues related to that, but toe is what's going to eat your tires in the short run.
                          I killed a set of tires at stock height in less than 20K miles because of toe. I then lowered and had everything set up, and didn't have any more wear issues.
                            You should see some camber wear when lowered... 2"+ is where it usually gets bad. I'm on H&R Race springs, and I'll be getting a camber kit very soon. A camber kit is never a bad idea. All 4 corners would be cheaper than new tires... so it's best to do it.
                            Also, to the OP... Unless Konig recently released the Helium in 15" with a 4x114.3 bolt pattern, they will not fit on your car. I contacted the company to ask about that a few years ago, and they told me they are in 4x100 only. Sucks.
