exhaust
    exhaust
    would 2 1/2in be 2 big
    That would probly be just right, even if your engine is stock. If you are upgrading the exhaust system, 2.25 to 2.5"
      exhaust
      cool thanks
        I had 2.25 on mine, i've heard 2.5 is a little to big unless you have more mods. The muffler shop I went to recommended 2.25
        Formerly know as accord-racing Jan 06 - Dec 07
        BOUGHT FROM: cb95spd, lildeez07, L3G10N, JARHEAD293, True-BlueCB7, Boost_Lee, djcaz_aom, zmiennik
        SOLD TO: treyd82, Sneakerhead28, BoxMan, civic_90_08, greenmachine9, baracuda, zmiennik
          2.5" is right for an H22. 2.25" is better for an F22. If you plan on swapping, or going with some more major modifications (headwork, cam upgrade, etc...) then 2.5" would work.
          2.5" won't hurt anything, but if you're just doing the basic stuff, 2.25" is the better choice.
            aren't greddy evo's 2.36 in.? like 60mm or something like that?
              Yeah, most of the Japanese systems are 60mm.
                What is stock suppose to be?
                wat?
                  1.8", I believe? I'm not 100% positive though.
                    Yeah I'm not sure 1.75 maybe?, I asked because I know the pipe that goes from the cat to the axle was replaced on mine, it it looks pretty big. Bigger than 1.75 for sure. The axle back I bought was 2" and its still bigger than that too.
                    wat?
                      Probably 45mm, or roughly 1.8". Unless you're running a turbo or a high compression engine with a strong cam (e.g. an H22A) 2.25" should be the correct size to run. Any exhaust larger than that will start to hurt your performance rather than than help it.
                      ~If everybody you knew jumped off a bridge...the bodies would pile high enough to break your fall if you jumped after them.~
                      Project Deerslayer
                      UPDATE: DEER - 2, CB7 - 0
                      '93 EX 5-speed coupe
                      Short ram intake
                      Tenrai Himoto catback
                      Smashed front end
