i want to know what is the difference between 92 accord ex and accord lx. what different with the computer, engine, braking, i need a full list?
what is the difference between 92 accord ex and lx
to my knowledge the 92 ex and lx are two completely different animals. The ex (that I have) comes stock with the F22a6 and the lx has the F22a1. These engines are very different, not only is the ECU or, "computer" different, but the engine is as well. The camshaft is a little bit more radical in the a6, this meaning the lobes on the camshaft have a little bit more of a point to them keeping the valves open longer; thus, better performance. Also, the intake and exhaust manifolds are different. The a6 exhaust manifold has a 4-2-1 setup whereas the a1 has a 4-1 setup. However, if you so desire to upgrade the exhaust manifold, it would be worth your while to upgrade to the a4. For whatever reason, Honda decided to put the best manifold on the middle class engine that can only be found in 1990 and 1991 Cb7's that come with the F22a4. Lastly, the upper plenum is best in the a6 because it has fully operational butterfly valves which give more high end power when needed and has more area on the inside of the plenum creating more room for air to be forced into the engine. I am only unsure on ABS and rear discs in the 92 lx. I know it comes stock in the 92 ex, but it may not come in the lx. Hope that helps.
Yea man, the EX and LX and completely diffirent from 90-93,
1992 EX LX
Engine: f22a6 f22a1
Cams: a6 a1
ECU: pt6 pt3
Exhaust: Dual-tip single-tip
Brakes: F/R Disk F Disk,R Drum
ETC.: Intake, sunroof, ABS, wheels, tire pressure, radio, front lip, and Im pretty sure there is more, hopefully this helps.
Originally posted by blaxemjYea man, the EX and LX and completely diffirent from 90-93,
1992 EX LX
Engine: f22a6 f22a1
Cams: a6 a1
ECU: pt6 pt3
I know that the 93 LX Special Edition has ABS but no sunroof. im not sure on the engine for that model
Links to my rides :
1992 Accord EX*
1990 Accord EX
1991 Accord SE (4th)
1991 Accord SE (3rd)
1991 Accord SE (2ND)
1991 Accord SE
someone had recently mentioned the A6 had a baffled oil pan? Didn't hear any confirmation or denial on that, though I think this would've been more widely known if it were true.Opal Metallic Green '92 LX 2dr manual, 181k miles, '94 prelude VTEC wheels for summer (steelies with snow tires for winter), Omni-power struts/springs, and other junk
my daily driver. (AOM June 2010)
"she may not look like much, but she's got it were it counts kid. Made a lot of special modifications myself."
MR page
http://www.cb7tuner.com/vbb/showthread.php?t=76111
Originally posted by iladelwill085i want to know what is the difference between 92 accord ex and accord lx. what different with the computer, engine, braking, i need a full list?
- PT6 ECU (140 HP motor)
- more aggressive camshaft
- dual runner intake manifold (better)
- different exhaust manifold 4-2-1 (better)
- 4 wheel disc brakes with anti-lock brakes/ABS
- external ignition coil design
- windage tray & different oil pickup present
- oil cooler present
- same oil pump
- sunroof present
- alloy rims 15x5.5
- dual tip muffler
- 1" bore master cylinder/larger brake booster also
92 Accord LX:
- PT3 ECU (125 HP motor)
- less aggressive camshaft
- single runner intake manifold
- different exhaust manifold 4-1 (not as good as EX)
- front disc/rear drum brakes, no ABS (except on 93 LX 10th anniv. edition)
- no windage tray, different oil pickup present
- no oil cooler present
- same oil pump
- no sunroof
- wheel covers on steelies (14x5.5 or 15x5.5 rims, not sure..93 LX 10th anniv editon has 15x5.5 alloys)
- single tip muffler
- 3/4" bore master cylinder/smaller brake booster alsoLast edited by HondaFan81; 01-25-2008, 11:45 AM.
