????'s
    ????'s
    Does the SOHC fuel pump affect a swap F22B... performance wise.. well it feed enough fuel for the motor or is it just the fuel injectors job??? Should I just make sure i have the F22b's injectors when installing???
    anyone know???
      Relax man. You posted your question at midnight. The fuel pump is important, but your stock F22A pump should have plenty of flow to feed an F22B. If I were you, I would try to get the injectors with the F22B, as they would be sized properly to feed the cylinders.
      ~If everybody you knew jumped off a bridge...the bodies would pile high enough to break your fall if you jumped after them.~
      Project Deerslayer
      UPDATE: DEER - 2, CB7 - 0
      '93 EX 5-speed coupe
      Short ram intake
      Tenrai Himoto catback
      Smashed front end
        Basically what he said. As I recall they are the same size injector as the f22a maybe.
          SOHC F22A* & DOHC F22B fuel pump and injectors are the same. No problems using either.
          MR Thread
          GhostAccord 2.4L Blog
          by Chappy, on Flickr
            My stock fuel pump, original from 1992, has been feeding my H22A for almost 5 years with no problems whatsoever. The H22 injectors are 345cc. Your F22B injectors should be the same flow rate as the F22A, which I believe is 240cc. If I'm correct, there's no change. Regardless, the H22 has the largest injectors of all B/D/F/H series engines, and if that works fine, you have nothing to worry about!
            Of course, if you want to upgrade your pump, it certainly won't hurt.
              thanx guys...sorry for the rush. i didnt realize the time when i posted my question
