what can i do
    what can i do
    ok ive got a 90 2 door wiyh a 5 speed. i bought it from a friend, but his motor was shot, but it ran. i pulled the motor and put anothe f22a1 in it same set up. i am getting no fire at all. i even swapped distribitors modules caps rotors, i mean everything ignition wise still no fire. the cam is spinning i pulled the cap and the rotor is turning what tha fuck
    AUTO REOLUTION : A BAND OF BROTHERS FROM WEST TENNESSEE WE LIVE AND DIE BY THE NEED FOR SPEED
    have you checked the main relay.. that is one of the most common things that will go out or is not working properly.
    Originally posted by Devergote
    A CB7 with an H22, a clean paintjob, HIDs with a projector retrofit, some nice wheels, and a mild drop on H&R Sport springs and Koni Yellow shocks... that's the perfect car. I'd be happy with that for the rest of my life.
      is the ground on the thermostat in tact? thats the ecu ground located directly under the thermostat.
      so you get no spark correct?
      Retro!
      Hater
        ok
        like under the housing by the coolant temp sensor
          i checked all the fuses, but not the main relay, thats funny though that u mention that cuz my fuel pump relay was shot; i just jumped the 5 and 7 teminals
            yes... there should be two grounds connected into one that is grounded by a 10 mm bolt that is on the thermostat housing.
              if you jumped the terminals then it might be your main relay since it controls all that.. not a good idea to jump it.. .. i would go ahead and replace it .
                locate thermostat housing and directly under it should be a bolt with 2 grounds g0oing to it...if you did the swap it can be easilly overlooked.
                also check ecu fuse.
                Retro!
                Hater
                  dude i think thats it i remember now takink that bolt out, but uhhhh not puttin that back in
                    wheres the main relay located dude it took me 4 days to find the pump relay i think my car is tempermental cuz i cussed he a little bit lol
                      good luck with the car ... hope its just something simple.
                        check your firing order
                          The firing order can be off and you will still be getting spark. Did you check to see if the ecu ground is put back on? Most of the time that is the case.
