Is it possible?
    Is it possible?
    Is it possible to put an h22 head on a f22 block?
    my ride page
    http://www.cb7tuner.com/vbb/showthre...24#post1781524
    No its not, but with some modification, you can put an H23 Head on an F22 Block. and that would give you about 160 HP to start with.
    Fun with Paint... haha.
    OHIO CB7's
      wrong. know what you're saying before you give off false information.
      its possible. there shoulld be a write up somewhere on here let me try to find it for you.
        Thanks
        my ride page
          this has some info in this thread here... check it out
          http://www.cb7tuner.com/vbb/showthre...ghlight=hybrid
            Thanks alot
            my ride page
              ahhh im sorry man, ive always thought to believe that it was only an H23 head swap that would work. Ive thought to believe that for a while, actually knowing that it CAN be done, sparks my intrest. but ya, sorry again
              OHIO CB7's
                It can be done, but you end up with a low compression engine (somewhere around 8:1). Which is good, I guess, if you wanted to turbo.
                1992 Prelude S w/swapped H22A
                  You're better off doing the H23 swap. The H22 head is designed to work with a high-compression engine, and you'd end up with basically not much more power than you already have with an F22A.
                  ~If everybody you knew jumped off a bridge...the bodies would pile high enough to break your fall if you jumped after them.~
                  Project Deerslayer
                  UPDATE: DEER - 2, CB7 - 0
                  '93 EX 5-speed coupe
                  Short ram intake
                  Tenrai Himoto catback
                  Smashed front end
