I'm curious. Does a civic radiator fit into a cb7? My radiator is leaking so I found this alumimun radiator that is 2 inches thick.
Radiator?
As long as its a dual core 92-95 civic radiator. It has to be Dual core or your gonna overheat. They came in the EX/SI civics.
By the way F22HB, I am so curious about how you managed to weld the axles together on your ride. Of course, I'm still excited about your successful swap (that's because I just found out about it the other day). I would imagine that you reinforced the welds someway. But what and how exactly did you attach the cv axles together? if you don't mind telling.
The civic axles are hollow and the accords are solid. they happen to fit into eachother prefectly. From there we welded them together with and drilled through it all and welded in a pin through each. They work perfect. I have no doubt in my mind the cv joint would snap before the axle.
Back on topic... you still tryin to get that radiator?
It's funny because Miata people are asking the same question too:
http://clubroadster.net/forum/viewto...ighlight=civic
The reasoning behind this question was to either increase space in the engine bay or to relocate the radiator for a v-mount setup or for more efficient airflow.
I'm curious, are you thinking about this from a performance standpoint as well or a financial standpoint?Last edited by Lonehousewife; 01-20-2008, 11:50 PM.1996 Mazda Miata.....uh, I think I made a wrong turn on the internet somewhere....
