yesterday I started smelling fuel inside my car. I open the hood and the smell was coming around the back were the fuel injectors are located. can m injectors be the problem? 180k on the engine.
Fule Injector Problem ?
Links to my rides :
1992 Accord EX*
1990 Accord EX
1991 Accord SE (4th)
1991 Accord SE (3rd)
1991 Accord SE (2ND)
1991 Accord SETags: None
i don't see any leak just smell it, i think it would be a much bigger smell if it was leaking out fuel don't you think?
Links to my rides :
1992 Accord EX*
1990 Accord EX
1991 Accord SE
Originally posted by Hondateck2010i don't see any leak just smell it, i think it would be a much bigger smell if it was leaking out fuel don't you think?
I have no clue were the evapis at, sorry guys im not that good can someone explain where its located? also the car is not doing so good with gas like it did before, its been going fast, i don't know if the fuel prices is doing it but im only getting about 90 mpg on a half tank. is those #'s right?
another question (i know its to many)
Can someone please give me a list of all the things that needs a tune up after hitting 180k ?
Links to my rides :
1992 Accord EX*
1990 Accord EX
1991 Accord SE
check the injector seals...those may be leaking...also check the fuel lines going to the fuel rail or around your fuel filter...
heres a diy for injector seals they are really cheap if u do need to replace them
http://www.cb7tuner.com/vbb/showthre...light=injector
