ordered new head from advance auto,also all new belts, water pump,n so on.the head was complete,n my mechanic transferred the rockers from the old head and put in my new camshaft,we lined all the grooves and notches up.pretty sure he had the motor at T.D.C. started it up n the head was making a loud popping noise.took the valve pan off n noticed some valve springs were sticking. did we not put it in time right n if not what else should we have done for the timing. my mechanic says the head was deffective so i got another head,but still waiting for next install,hope to not repeat ourselves this time ,any advice.
still need help with cylinder head install
1. Buy a manual
2. Check valve adjustment before installing always. Those shops usually dont adjust the valves when you get the head back.
i got a manual.this sounds dumb but do we need to use a timing gun, or will it be in time good enough,with the gears n notches all lined up. what would make valve springs stick? the car started right up just had a loud popping. any advice on maybe getting my orininal head refurbished n shit. oh yeah, how would we check the valve adjustment cuz my dude says he did all the shit right but hows a company gonna mess up,assembling a head when thats what they do ya know.oh yeah do u know anything about placing a 8mm pin or equivalent size or sumethin in the back of the block during the head change? read it in the manual wasnt sure if that needed to be done.Last edited by therealness; 01-16-2008, 11:40 AM.
Originally posted by therealnessordered new head from advance auto,also all new belts, water pump,n so on.the head was complete,n my mechanic transferred the rockers from the old head and put in my new camshaft,we lined all the grooves and notches up.pretty sure he had the motor at T.D.C. started it up n the head was making a loud popping noise.took the valve pan off n noticed some valve springs were sticking. did we not put it in time right n if not what else should we have done for the timing. my mechanic says the head was deffective so i got another head,but still waiting for next install,hope to not repeat ourselves this time ,any advice.
2) Get a manual to verify you are setting the physical timing (cam gear vs crankshaft relation) in the correct manner. Look in the technical section stickies and see "online resources" for a PDF file of whatever you need from a manual if you're cheap. Print that off for a guide.
3) I would get help from a different mechanic because it seems like he is familiar with these motors at all.
4) Any head from sitting around, smack the top of each valve with a plastic/nylon/rubber mallet a few times each to unstick the valves from the guides. I personally found this can happen when a head sits for months, awaiting installation. Remember, you bought it pre-assembled and it could have sat in warehouse for a while before you got it.
Originally posted by therealnessi got a manual.this sounds dumb but do we need to use a timing gun, or will it be in time good enough,with the gears n notches all lined up. what would make valve springs stick? the car started right up just had a loud popping. any advice on maybe getting my orininal head refurbished n shit. oh yeah, how would we check the valve adjustment cuz my dude says he did all the shit right but hows a company gonna mess up,assembling a head when thats what they do ya know.oh yeah do u know anything about placing a 8mm pin or equivalent size or sumethin in the back of the block during the head change? read it in the manual wasnt sure if that needed to be done.
Get a manual or reference one like I said in previous post! It's in our forum. Again, leave that mechanic and find another or local member near you, this guy obviously does not know this motor!
He didn't say he transferred the cam caps from the old head onto the new, but yeah, that shouldn't be done. They are a matched set with the head.
As for valve adjustment: Get yourself a set of feeler gauges. That's all it takes to check the alignment. If you want to adjust them, there's a special tool that allows you to hold the slotted screw of the rocker adjuster, while tightening the lock nut. It's not essential, but its nice to have.1990 Accord LX Sedan, B-49M
