I have researched as much as possible and I still have some basic questions.
I tried to access the swap thread: http://www.cb7tuner.com/vbb/showthr...s=&threadid=523. And the link won't work. Please help me with some much needed information, I will be starting the swap in a few days, here is what I am working with:
92 Accord EX Coupe F22A6 with H23 Manual Transmission swapped in.
Putting in:
99 H22A4
SH Intake manifold-97 lude Throttle Body(Ext. MAP)
JDM wiring harness for pigtails
H23 manual timing belt tensioner swap
New head gasket, valve cover gasket, seals- the works
Externally coiled distributor
I know I have to do some wire lengthening for the 02 sensor and the oil pressure sensor. And I have to run wires for VTEC, knock sensor, etc. (not sure about all of them). I also need the H22A4 basemap, because I have a chipped p28 and just need the bin file for the new motor.
If i missed anything let me know. Also, please help me with the wiring, that is giving me a lot of trouble since it is an OBDII(B) motor (i think).
Thanks for any help you can give me!
Putting in:
99 H22A4
