90 accord ex overheating
    ok sense all of my other posting never really get answered corectly im doing a new one...
    Car warms up fine then overheats. No heat what so ever. no collent smell or loss. did notice there is very little pressure when i remove the rad. cap
    Bled and filled the system: done that
    thermostat: replaced
    water pump: replaced
    Fans: kick on
    temp. gauge: tested and works properly
    is there a way to test to see if the headgasket is fked
    anything else it could be just tell me
    Engine:
    stock F22A4
    Cold Air Intake
    2.5in Exaust No Cat toTip
    Interior:
    Short Shifter
    Exterior:
    5% tint all the way around
    15in gun metal with crome lip rims
    DIY jdm black headlights
    Future Mods:
    DSM Turbo
    Check your oil if it's milky.
    Did you also carefully check all of your hoses? Even a slight leak will make it overheat.
    1996 Honda Civic LX 2009-2012
    2012 Kia Optima LX 2012-2013
      the oil is not milky and all the hoses were replaced during the swap
      Engine:
      stock F22A4
      Cold Air Intake
      Interior:
      Short Shifter
      Exterior:
      Future Mods:
      DSM Turbo
        Re-bleed it again. Air might still be trapped inside.
          Go to auto zone and do a pressure system test that will fine any leaks you may not see, I think you pump it up to 15 pounds but no more.
          Click Me
            ive bled it 3 or 4 times ans the closest auto zone is 30 min away and i cant make it that far with it over heating
            Engine:
            stock F22A4
            Cold Air Intake
            Interior:
            Short Shifter
            Exterior:
            Future Mods:
            DSM Turbo
              Might be the radiator itself.
              "form follows function."
              Louis Sullivan
                take it down to a Mechanics and have him pressure test the system.
                Click Me
