exhaust knowledge
    exhaust knowledge
    i just want to spread some knowledge here about exhaust design and fabricating...
    -the higher flow the muffler you put on your car is the higher rpm your power and torque will be at... other things that have this effect are
    -bigger piping
    -headers
    -higher flow cats and/or test pipes
    -on daily driven cars these parts will reduce the amount of power at the lower rpms of the rev range, since you have to rev higher to get the same amount of power your gas mileage will go down, also when there is less backpressure to slow down exhaust gasses they will not be able to hold seals in the engine properly, and the engine will slowly burn through such things as piston rings and head gaskets. remember that honda designed these cars engines with that specific exhaust holding a certain amount of air pressure into the cylinder of the engine on the exhaust stroke... also the o2 sensor not only determines how much to richen or lean the engine but also the amount of flow in the exhaust it can only properly adjust to about 10% more or less than the normal exhaust flow any more than that and you may have problems with running rich. a good performance muffler for a 4 cylinder car will need to still have some backpressure otherwise you may need to get your computer reflashed and that will only take care of the fuel mixture you will still have to take care of your seals... also remember that in order to run a good performance exhaust you also need to run a higher flow intake to keep the air coming in the engine as fast as it is going out of it... a good ides if you like those canister style exhausts but don't want to risk your engine is to put a muffler upstream of the rear axle and continue the piping to the canister at the bumper... but anyway i know a lot about exhaust if you want to know how to get the perfect balance for your car i can suggest some mufflers
    back to do it again... no flipping of accords this time!!!
    Hit me up with techy questions if i don't have an answer i can get an answer...
    i have a apexi ws1 exhaust, ebay 4-2-1 headers on my del sol with 2 1/4 inch piping, do you think that holds enough backpressure to keep my seals from going bad
      Cool. Where did you study?
      Please tell the rest of us why less backpressure will blow out seals.
      2003 Maxima SE Titanium Edition
      1993 Suzuki GSX1100F 136bhp
        jesus christ
          I think we need a sticky solely for exhaust info, questions, and possible upgrades...
          My Black "H"
          AL Meet!?
          //Secret G2I Lover, Shhhhhhh! //
            Originally posted by fizzbob7
            jesus christ
            I liked your 1st response better.
            To the OP:
            That is a hefty claim to be making about yourself. If you are indeed the "exhaust design master" your knowledge would be of use to a lot of people here. What school or research have you done to obtain this knowledge?
            Not flaming you, I am just curious.
            3 CB's gone....
            1 WK Overland....
            Still miss the CB though......maybe one day.
              it would just be a lot of posts pertaining to very different setups, how they sound and a lot of basic info coupled with opinionated info. really isn't a point.
              have a mild n/a setup? go with a 2.25-2.5" setup. want it quiet? use a longer resonator, high flow cat and quality muffler. want it loud? don't use any of that shit.
              extreme n/a setup? then you don't need exhaust advice.
              turbo setup? bigger is better, but you only have so much room. same rules for quiet apply.
              there you go
                Well, really just for the begginer section. I think that would help alot... Hey man, what part of alabama is athens in?
                My Black "H"
                AL Meet!?
                  Copy and paste lol.
                    north, around huntsville and decatur. is t-town tuscaloosa?
                      Oh yeah tuscaloosa , haha, huntsville you say?. Its gonna be a meet up there soon
                      My Black "H"
                      AL Meet!?
                        i wrote a more coherent beginners guide to exhaust theory here.
                          -bigger piping
                          -headers
                          Then why have I seen headers that have improved power all the way from idle to redline?
                            I have a jet engine does that count lol.
                              Jet engines ALWAYS count!
