I'm yanking out my blown 92 f22a4 engine and replacing it with a 91 auto f22a1 engine. Obviously I know to use the 5spd 92 engine harness and remove the flex plate & swap in the flywheel. But how about other things like the throttle body?
auto motor as replacement for a 5spd motor?
Originally posted by Chaos325I'm yanking out my blown 92 f22a4 engine and replacing it with a 91 auto f22a1 engine. Obviously I know to use the 5spd 92 engine harness and remove the flex plate & swap in the flywheel. But how about other things like the throttle body?
Everything else is the same. You will have an extra bracket that is screwed the to the TB, but you can just remove the 2 screws and you will be good.
Originally posted by yblegal08i dunno if the accords are the same, but i know when i put an auto motor in my integra the auto cams had a different cam profile, making less power. also a different intake manifold is usually on a auto compared to manual....
but for the most part should be a basic drop in.
Accords are not Integras. The same things don't apply.
The Accord cam profiles are basically the same from auto to manual, as long as the engine has the same designation as the one it is replacing.
All F22A1 and F22A4 cams are the same. The F22A6 has a slightly hotter cam, but it doesn't change from auto to manual.
Originally posted by cb7addictgood luck with the swap, you will enjoy it alot more89 Acura Integra 1.6 LSt (Daddy's Boost Toy)
94 Honda Accord 2.2 EX (Daily For Now)
04 Chevy Suburban 5.3 LT (Kiddie Haulin Pimpness)
