hey guyz i have bulit a 12.1 to comp eng and it uses a lot of oil but there is no leaks and like 275 psi comp per cyl and the plugs are clean when i pull them out i mean a very excesive amount of oil the head was rebuilt at a local macine shop could a valve seal already be bad or have gotten damaged on the exhaust side. the seals were replaced but the guides were not could this be why is uses oil but doesnt show on the spark plugs i dont ever smell burning oil or never see it smoke and no one has ever told me it smokes but if it setts over night or a day or so it does smoke just for a few sec after start up, engine has all new every thing internal and external has total seal gapless rings i have heard that they may cause a little oil uses but this is unnessasery usage also has new pcv and hose so i no that the crank case is breathing properly if any one has any ideas shoot them my way i want to do a h23 head swap any way so if you think it may be the head tell me, also befor it was built it was doing the same thing but it was smoking like a mother fucker and the plugs were constantly fauling out and were just covered with carbon and gumk from burning oil , and the rings were stuck in the pistons but now i am clueless as to were in the hell it is coming from
new engine uses oil (PLEASE HELP)
Originally posted by quickangel93guides need to be replaced. why would you build a head without changing the guides?90 Accord EX F22a1 Auto R.I.P.
2011 Mazda 3 Hatch 2.5L GS sport HELLO!
Originally posted by Devinyea its has 89mm forgeed pistons yes bored and honed and new total seal gapless rings and the head did not get a lot of money put into it because i wanted a h23 but at the time couldnt find one
'Gapless' rings may sound like they'd just have to seal better than ordinary rings, but in reality make almost zero difference to compression. The amount of pressure leakage through ring gaps is absolutely miniscule, barely measurable if at all. Tests have been done with ring gaps where the gaps were progressively opened up from spec to multiples of spec width with no compression change until the gaps are like three or four times as wide as the spec width (maybe more), and even with such wide gaps compression loss was only slight. I can't recall my source for this, something I read somewhere sometime.
A lot of engine builders tend to blame the gap when the engine loses compression because when they pull the motor apart they find the gap has increased substantially from spec, but this is merely normal wear. The real cause of the compression loss will typically be the loss of ring tension due to ring overheating (effectively anneals the rings) or rings sticking in the lands etc. The fact that you'll often find widened gaps on an engine that has lost compression doesn't mean that the gaps are what caused the compression loss.Regards from Oz,
John.
Did you break it in properly.
for fucks sakes man do you know what a period is?? well here is a few for the future...................................
