DRL Problem
    DRL Problem
    my DRL(day running light) is not working.i tired changing the bulb but still show the drl on. any 1 have suggestion how to fix it.
    thanks
    My signature works perfectly fine.
    Check the fuses first, and check for a power feed at the bulb when the lights are turned on.
    My 5.7 LS1 Holden Ute
      i already checked the fuse and it was ok..i'll look for the power feed to bulb...thx
        check the power to bulb..it's good. any other suggestion.
          Checked the earth also. Also bulbs have been known to be bad from new, But check the earth first.
          If youv\'e got power and earth it should work
            what's an earth?
              is there a noise coming from the glove box area when your lights are off?
              if so then your DRL module is shot
              Hold On Not Done Accelerating
              Had One Never Did Again
                Originally posted by psycobone
                what's an earth?
                different way of saying ground
                  o ok.. and no there's no noise coming.. just yesteray the DRL light went away..so i got off the car and cheked there was still no light in the headlight. when i restarted the car the DRL came on.
