Hi, I have a 92 honda accord exr 5sp.
Heres the deal:
The left turn signal light stays on (does not flash) all the time even with the key out.
It doesn't matter if I unplug the headlight/turn signal switch, flasher relay, 4-way flasher. The light stays on.
I started removing fuses 1 at a time from under the hood and when i unplugged the interior fuse the light went out so i know I have a short.
It's actually kinda funny cuz the dome light flashes with the left turn signal now (i actually turn the dome light off cuz it got annoying).
I guess my question is has anyone had this problem before?
I think the problem is near the fuse panel or atleast tucked up in that area.
The only other electrical problem with the car is that the left high beam doesn't work and the right one works most of the time.
Heres the deal:
