i final got my cars check engine light on after iv been having problems for the past month i got a code 43 watch is fuel supply system can anyone help...
code 43
I got it like 2 weeks ago, replaced my O2 sensor and it took care of it, but it can be several things. Basically, you throw a 43 when the engine gets too much or too little fuel, which could be injectors, thermostat/temp sensor, O2, but most people fix it with the O2. So when was the last time the O2 was replaced? (OEM parts only)
Originally posted by accordaffairI got it like 2 weeks ago, replaced my O2 sensor and it took care of it, but it can be several things. Basically, you throw a 43 when the engine gets too much or too little fuel, which could be injectors, thermostat/temp sensor, O2, but most people fix it with the O2. So when was the last time the O2 was replaced? (OEM parts only)
Originally posted by inferno1414ya, because one of the most important sensors that adjusts the a/f ratio is the o2 sensor. See your o2 probably still works, but sends the ecu a weak signal, or delayed signal...hence wrong a/f ratio at the time it's needed. its a good place to start.
I don't go cheap on O2's anymore cuz they are always crap, even the boschs have given me problems even though their stuff is usually really good.
I go OEM always for the O2 now, NGK, Denso, etc. Hit up your dealer or just buy from majestic or slhondaparts.
i have dcheader and catback its from my old car so its been about...5 or more years lol...and that would cause my car to struggle like that and start to miss and back fire and shit like that?
I guess just save for a little while longer, because when I bought bosch O2 sensors they did wierd things, like make the tach/engine jump/search, or make the mixture too rich, they just didn't work as good as an OEM part does.
1. Bosch is ***.
2. NGK/Denso is the other replacement to OEM and slightly cheaper.
3. OEM might have a high tag it's still the best one out there.
