I usually check the coolant level once every month or so and these last two months I've had to add probably 1/2 liter of coolant. I replaced the t-stat and the 2 main radiator hoses at the end of the summer. I'll have to double check but there are no visible leaks. I would prefer there to be an external leak haha because I'm sure any internal problem would be a lot bigger of a problem..
What could be causing this? I doubt that much coolant loss over one month is normal..
Thanks
Thanks
