need some advice
    need some advice
    was trying to figger out why my temp is normal an my fan works but when i pop my hood, there's exstream heat coming from the motor sometimes it smell like something is burning .....there's no leaks or smoke coming from any where...
    stevenoreaga215
    SUP, my car is the same way. But thats cuz im beatin my car when i drive.
    Im also do for a oil change, once i do this the car wont b as hot.
    This is what happens when i do it, i dunno about others.
      yep
      thats what happens when i drive hard on my car.
      ^^^^^but he is right might be tune up time
      Cappuccino CB7 Member #4
      FoDough fo moreho
      [FuNKiE FrEsH]
        Its normal....The car runs at an optimal 190-200 degrees constant...Your going to feel heat its common sense. If your temp gauge is reading properly then its ok. The fan turns on when it sees the engine reading 220 as I recall.
          my car is the same
          My car gets pretty hot even though the temperature gauge is right in the middle. I thought it was overheating first as well but I was driving in the summer as well.
          I opened up the hood, like this heat wave hit me, checked all the coolant, fully topped up, I guess its the fault of honda.
          Well a mate of mine's car overheats, he changed his radiator, but he used water instead of coolant in his radiator and that rusted a few holes in his radiator to cause his car to overheat.
          if its not a honda, its not hot
            did you change ur oil resently? that could be burning if it dripped or is your temp gage normal? do you have your heat sheild on the headers cuz if not that will makethings hot under there
