rough power steering + squeaking noise
    it all started yesterday... i thought it will go away after i warmed the car up but it didn't.
    it feels rough and a bit tight when u turn the steering, and squeaks... and i noticed that the power steering fluid was all bubbled when i check the reservior
    will new power steering fluid help? how do i drain it... or i need a new pump/rack?
    my rims cost more than my car
    hmmm sounds like ur pump is seizin up might need a new p/s pump
      are you low on fluid? if you have bubbles you could be low and you are getting air in the system
        Is your fluid dirty for a long time?
        If yes it might have fucked your system. I suggest replacing it if you havent done so.
        1996 Honda Civic LX 2009-2012
        2012 Kia Optima LX 2012-2013
          check if your fluid and if the rack is leaking.
            sounds like the pump seals are gone...with the car running is the reservoir frothing?
              i checked it when the engine is idling normally... it was bubbling
              ya and the fluid is low as well, will top up 2morrow and see if it'll get better
              issit a common problem for cb7?
                sounds like the PS pump is going out
                2004 Audi A4 Quattro 6 speed
                2002 Chevy 2500HD LQ4
                1995 SE 240sx 5 speed Ka-T re under construction
                1991 240sx current paper weight for sale
                Have a 240sx Q ask me
                Sorry I just think body kits are ***.
                Still lurking around......
                  well i wouldnt say its common, it can happen to the high mileage cbs, or ones that have used an 'additive' in the ps fluid. basically air is getting into the system somewhere it should...most likely occurs at the pump seals
                    so does topping up the fluid help? or do i need to replace the seals? how hard is the replacement?
                      topping up wont do anything, most likely the air is gettnig pulled in from somewhere it shouldnt. If the pump requires a rebuild its not too difficult, just basically taknig it off the car, taking it apart and putting it back together the same way.
                        also good idea to replace the belt while your in there
                          i added some ps fluid and it turns smooth now with no squeaking... guess the fluid was runnin low and trapped some air...
                            I have this problem..
                            use Lucas Oil power steering fix..
                            it doesnt fix the problem but it fixes the symptoms.
                            mine still leaks a bit ( alot less after the Lucas) but no longer screams or feels chuncky when turning the wheel..
                            I can run the resivoir dry and it will still be smooth cuz of the Lucas oil..
                              im interested to see how the pump will be in a few months
