idle screw
    idle screw
    just how tight should the idle screw be. i got most of my surge gone but theres still a slight bit there that i wanna clear up
    put it to where it idles at 700+/- 50 rpm
    wat?
      well i jus cranked her down the whole way and so far its runnin fine. i also retightened the fitv screw. im gonna take it 4 a ride here in a bit when i pick the ol' lady up from work and see how it does.
        Your idle speed adjustment screw should be adjusted so that your car idles at 650-750 rpm (500-600 with the IAC Valve connector disconnected) When your car is idling at the rpm specified on the VEIC label under your hood then that is when it is tight enough.
        Any adjustments to your idle speed screw should be made only when your engine is up to running temperature. As well you should reset your ECU after any adjustments.
        If you are still having a surging idle the idle speed adjustment screw is not your problem. unless you have it backed all the way out or it is broken.If you have it screwed all the way in and your car runs fine then you might have a vacuum problem somewhere else.
        MR Thread
        GhostAccord 2.4L Blog
        by Chappy, on Flickr
          yeah its still surging. im gonna pick a can of carb cleaner up and see if there is a leak.
