You have to enlarge a hole for the Cold air.
what is better a short ram intake or cold air?
yeh
the hole were the factory black plastic pipe goes down under the bumber ....my pipes diameter was to big to fit through the hole so i made the hole biger wit an eletric saw it was easy though.... hey how low did u drop ur car looks good thinkin about dropin mine after winter..a person who looks at somthing and see it as waste is no person at all but he who see what it could be will suceed
out with the old and in with the new
I like the suction/deeper sound a cold air makes, it also makes more power since it gets the cooler air from the bumper vs. inside the engine bay. If you live in a dryer area lilke AZ then get the cold air hands down. If you live in Seattle or something, def. get a bypass valve with the cold air.
Originally posted by jaykilla116the hole were the factory black plastic pipe goes down under the bumber ....my pipes diameter was to big to fit through the hole so i made the hole biger wit an eletric saw it was easy though.... hey how low did u drop ur car looks good thinkin about dropin mine after winter..
kool kool, i lowered it like 2 1/2 inches in the front and like 1 1/2 in the back...
and i live in new mexico so i think id be ok with the cai. i have short ram now but imma get me cai soon..
93 accord lx
ur sig is huge**Blk Housed Slut Crew Member #1**
Real world difference between cold air and short ram might be a single horsepower. F22HB is right: spend your money where you're going to make some real horsepower, like getting a cam from either Delta or Bisimoto. (I recommend Bisi.)
A cold air intake can very easily suck water into your engine if you run through a decent-sized puddle. The vacuum of the engine drawing in air sucks the water up the intake pipe and into the throttle body. Water doesn't compress. When it gets into a cylinder, you run into something called hydrolock. The air compresses as far as it can, then the piston runs into the water and stops dead. The results can be pretty dramatic, as I'm sure you can imagine. If you think you might run into any decent amount of rainfall and you're installing a CAI, do yourself a favor and get a bypass valve.~If everybody you knew jumped off a bridge...the bodies would pile high enough to break your fall if you jumped after them.~
Project Deerslayer
UPDATE: DEER - 2, CB7 - 0
'93 EX 5-speed coupe
Short ram intake
Tenrai Himoto catback
Smashed front end
To top it off just make sure you secure the CAI I learned my lesson the hard way. I do miss CAI but eh I get what I pay for lol.Henry R
Koni/Neuspeed
1992 Accord LX R.I.P
1993 Accord EX OG since 'o3
Legend FSM
Originally posted by CamuraiReal world difference between cold air and short ram might be a single horsepower. F22HB is right: spend your money where you're going to make some real horsepower, like getting a cam from either Delta or Bisimoto. (I recommend Bisi.)
A cold air intake can very easily suck water into your engine if you run through a decent-sized puddle. The vacuum of the engine drawing in air sucks the water up the intake pipe and into the throttle body. Water doesn't compress. When it gets into a cylinder, you run into something called hydrolock. The air compresses as far as it can, then the piston runs into the water and stops dead. The results can be pretty dramatic, as I'm sure you can imagine. If you think you might run into any decent amount of rainfall and you're installing a CAI, do yourself a favor and get a bypass valve.**Blk Housed Slut Crew Member #1**
cai owns sri.
get cold air with bypass valve (protects your intake from sucking up water if your intake gets submerged in water). with the bypass valve u have to cut the intake in half to put it in, cut it so in the winter (or rain) you can pull off the lower half and have short ram.
i think its smarter that way, thats how i have mine setup.
I haven't been able to find any video of the bypass valve in action, but this is a good article on how it works: http://www.sportcompactcarweb.com/te...lve/index.html
Sport Compact Car Magazine tested the bypass valve on the NSX owned and driven by John Concialdi, Chief Engineer at AEM. The car makes a reliable 250whp. They rigged up an external cold air intake tube out of clear plexiglass, then repeatedly dunked the filter in a fishtank full of water while Concialdi ripped off full-throttle dyno passes. The water never rose more than 18" up the intake pipe. When they pulled the filter out of the water with the engine still at WOT, the intake started to suck air through the water, whipping it into a froth, but it still refused to suck water into the engine. Feel free to read the article. It's entertaining, and very informative about the process of hydrolock.~If everybody you knew jumped off a bridge...the bodies would pile high enough to break your fall if you jumped after them.~
Project Deerslayer
Short ram intake
Smashed front end
CAI all the way...my buddy had a bypass on his and worked great...SRI u def lost power...you'd be better with a K&N drop in filter in your stock air box set up...SRI heats up alot if your idling in traffic for a while on a hot day...overall u cant even compare a CAI to a SRI...Last edited by 92coupe17; 12-23-2007, 12:56 AM.1994 Honda Accord SIR
-Apexi VTEC controller
-h22a swap
-5spd "LSD"
-DC header (CC)
-Injen CAI
-slammed 3" KYB adjustables Neuspeed springs
-skunk2 pro series intake manifold
-68mm TB
-Skunk2 adjust. cam gears/Camshafts Stage 1
-supertech springs/retainers
-DC short shifter
-type R boot and shift knob
-much more
1992 Accord coupe
-knock off N1 cat back
-Knock off test pipe
-fogs
-300k miles loves it
*SMOKE TIRES NOT DRUGS*
Originally posted by CamuraiI haven't been able to find any video of the bypass valve in action, but this is a good article on how it works: http://www.sportcompactcarweb.com/te...lve/index.html
Sport Compact Car Magazine tested the bypass valve on the NSX owned and driven by John Concialdi, Chief Engineer at AEM. The car makes a reliable 250whp. They rigged up an external cold air intake tube out of clear plexiglass, then repeatedly dunked the filter in a fishtank full of water while Concialdi ripped off full-throttle dyno passes. The water never rose more than 18" up the intake pipe. When they pulled the filter out of the water with the engine still at WOT, the intake started to suck air through the water, whipping it into a froth, but it still refused to suck water into the engine. Feel free to read the article. It's entertaining, and very informative about the process of hydrolock.Originally posted by 92coupe17CAI all the way...my buddy had a bypass on his and worked great...SRI u def lost power...you'd be better with a K&N drop in filter in your stock air box set up...SRI heats up alot if your idling in traffic for a while on a hot day...overall u cant even compare a CAI to a SRI...
Thank you, case closed.
