the "e-brake" light also will tell u if fluid is low...mine did that...thus being the talk about fluid...if the light is coming on check the fluid and see if its low...unless someone has messed with the line for the e-brake then it shouldnt kick on and be to to tight...also like stated above, the light has more then just one function...usually resulting in low fluid
e-brake light...
...if your ebrake cable is of adjustment ,worn or frozen it will stick and the light will stay on. When it gets cold outside like every other potential problem on your car it will show. Oh and your brake fluid should never be low,if it is something is wrong.Last edited by Fake Thug; 12-19-2007, 09:49 PM.
u may need some brakes.. i know when my brake pads are worn out my ebrake light will come on and off like when i hit my brakes and stuff like that. I got new brakes put on and everything was just PEACHES AND CREME from them on lol.. check into it. L8r
Originally posted by Juice21thnx pimpette, your car inspired me to go lowerOriginally posted by GameChewerShiit i heard that, you heard the queen!
