Use Lucas or Redline fuel system cleaner, they are proven much better than the other crap brands. I personally run Lucas "upper cylinder lubricant" all the time......I suggest you buy this and run about a triple dosage for 2-3 tanks then level off to normal usage for the next 5000 miles. And definitely change the fuel filter, as said before, it could and usually is the most likely to cause low power. Get a good fuel filter such as Purolator PureOne, don't get FRAM and don't get K&N (the 2 extremes).
Code 43
My Member's Ride Thread
Originally posted by 19dabeast85Use Lucas or Redline fuel system cleaner, they are proven much better than the other crap brands. I personally run Lucas "upper cylinder lubricant" all the time......I suggest you buy this and run about a triple dosage for 2-3 tanks then level off to normal usage for the next 5000 miles. And definitely change the fuel filter, as said before, it could and usually is the most likely to cause low power. Get a good fuel filter such as Purolator PureOne, don't get FRAM and don't get K&N (the 2 extremes).
----------------My 92 Honda Accord LX---------------------- My 97 Nissan 240sx LE----
NE GUYS, Buy the last of my accord parts
get a really good fuel filter like OEM!!! and what is upper cylinder lubricant? oil is oil! use bg products. bg 44k and moa for oil is proven to reduse wear and works! only one applicatin is nessassary!
member ride thread
DIVULGE MOTORSPORTS
yeah the OEM fuel filter is made by BOSCH, part#71504. I had a tremendous difficulty in even fitting the OEM fuel filter that i got at a Honda dealer for some reason so look into this thread for further explanation
Fuel Filter
Originally posted by JohnD1079i dont really think using that much fuel cleaner crap is food for your fuel system. I think that is wayy overkill and would do more harm than good.My Member's Ride Thread
Originally posted by turbo90accordget a really good fuel filter like OEM!!! and what is upper cylinder lubricant? oil is oil! use bg products. bg 44k and moa for oil is proven to reduse wear and works! only one applicatin is nessassary!
Lucas calls their product "Upper Cylinder Lubricant" but it actually is more like fuel system cleaner with slight lubricity additives to oil the top of the piston/walls/valves.
I know that regularly running it in normal doses over 10,000 miles has tremendously changed the way my valves and pistons look....via a boroscope!My Member's Ride Thread
code 43
I have exactly the same problem with my 93 SE auto. The only one I have not try is Sea-foam since my is almost 197K. Here is what the other thread I am talking about.
http://www.cb7tuner.com/vbb/showthre...highlight=tume.
One more thing the CEL is not lit up in the dash no more. However, the code is still there when I did the paper clip check. Anyone is welcome to chime in.
