valve cover breather smoking
    my breather on my valve cover is smoking alot, also its spiting oil though the breather. what do u thing it cool be?
    sounds like your piston rings are starting to go
    member ride thread
    DIVULGE MOTORSPORTS
      well im not smoking though my exhaust, but i think so too
        Originally posted by Otto
        How's about a new PCV valve before dooming the engine?
        ill go get one today and ill let you know
          Opal Metallic Green '92 LX 2dr manual, 181k miles, '94 prelude VTEC wheels for summer (steelies with snow tires for winter), Omni-power struts/springs, and other junk
            easy way to see if its rings is take off your oil cap when its running if smoke is coming out your rings are toast!
            member ride thread
            DIVULGE MOTORSPORTS
              If you are stating breather as in a breather filter you should change to a catch can tank immediately. The breather filter setup screws with something and allows for premature engine wear.
                This is false.. reason being that if you have a catch can or not either way its just being vented to the atmosphere versus being sucked back into the intake. a catch can only separates the oil from the vapor that it is suspended in which is vented through the hole which people put breather filters in. Its mainly there for emissions purposes so it gets burned off. A catch can is a better way of doing it. Either way smoke should not be coming out of it and if there is that means you have compression leaking into the crankcase past your rings. Highly suggest a compression test.
                member ride thread
                DIVULGE MOTORSPORTS
                  Owned!
                    Originally posted by F20A CB7
                    Owned!
                      ^lol^
                      And I never thought to open the oil cap and look for smoke...hmm
                      But yeah, do a compression test to be sure nothing bad is going down
                        ^lol^
                        ill do that and ill let you guys know.
