So I recently got my F22b into my cb7. I already did all of the wiring swap. It was pretty straight forward. I changed like 3-4 connectors and everything else just plugged right in. I also did everything to do a 5-spd conv. I just made my car think it was in park. I am running a P39 that came with the engine. Here is the problem I am running into. I changed the timing belt, balancer belt. Clutch, Flywheel, Pressure plate, and throwout bearing. Fuel filter, switched my fuel rail from my f22a to my 22b.
So here is the problem, I tried to start it last night and....nothing. It turns over, kind of sound like it wants to start, but nothing. I have spark, I have fuel...? WTF? I am also hearing this fucked up clicking sound. It kind of sounds like its coming from the transmission. If I put a socket on the crankshaft pulley, and spin it in the counter-clockwise direction, it moves a little than I hear and feel a click. I also can't get the damn, transmission into neutral. When I am turning the crank, I can see the gears in the transmission moving, when the trans should be in neutral.... I am stumped. Did I fuck up on the timing? Is that why its not firing up? One of my buddies stopped by to give me his opinion and he thinks I have the timing 180 deg off. What do you guys think? I need help on this asap. Please!
