Idle Problem....
    Idle Problem....
    Well my prcoblem is with the idle, ever time i put it into gear it dies. Or even when i turn the A/C on it dies to!!!!
    Thanks for the help.
    Ronnie
    my ride page
    http://www.cb7tuner.com/vbb/showthre...24#post1781524
    iacv
    check the iacv valve it supposed to compensate idle to engine load.
      I have checked the IACV and cleaned it and I im still having this problem.
      my ride page
        is you idle screw turned all the way in, the one on the throttle body.
        when did this start happening? was it after any work was done?
        Members Ride
          The problem has been there since i got the car! And what screw are you talking about? I really have not done any work to it because i have been real short on money!!
          my ride page
            there is a brown screw on your throttle body next to a red hose that goes into a nipple on the throttle body. it takes a flathead screwdriver. if that is all the way in then it most likely won't hold idle
            Members Ride
              Well if so is there a way to fix it so it will hold the idle???
              my ride page
